What do you do with a slush fund >4K...Buy a McIntosh MC275 IV Clone. Was on AliExpress last month on picking up some PCB boards, switches(testing) and came across Clones of well know gear. After IM'ing on details, I purchased Orsefon MC275 (McIntosh MC275 clone). Going over the pictures and asking many questions...$2200 and 3 weeks later we have an Amp. The circuit is based on MC275 IV.
1. 4-KT88, 3-12AX7, 4-12AT7...EH KT-88, 12AT7/12AX7 got me? LED Monitor lighting
2. Tube sockets bolted on separate metal board to prevent PCB cracking from Tube solder mounted sockets with Tube heat dissipation pipes.
2. Auto-BIAS system
3. System is monitored and Shut's Off (Relay Controlled) if Over-Volts, Clipping and Tube fails
3. Hand soldered WBT Silver
4. Gold Plated PCB Trace board
5. WIMA Films, Siemens Resistors, Nichicon, Rubycon, Philips Caps
6. XLR Balanced signal input (requires preamplifier drive)
7. RCA analog signal input (no need to drive by the preamplifier)
8. Mono output mode/stereo output mode
9. Balanced input selection/unbalanced (RCA) input selection
10. Left/Right channel volume adjustment (only for RCA analog input mode adjustment)
11. Output resistance group: 4 ohms, 8 ohms, 16 ohms
12. Gold Plated 5-way terminals
13. 1.75mm Gold Plated housing
14. Output power: stereo mono 75W / mono bridge method 150W
15. Coil 16 layers (the original Mcintosh MC275 is 12 layers) UP-OCC (single crystal oxygen-free copper) group cross winding method with the purity of single crystal oxygen-free copper 99.99%
16. Unit weight 68lbs (Yes, it is as I had to go up to 2nd floor)
Unit is running 10-12hrs per day (currently 30hrs) and I have to say...WOW. I cannot hear any "Hiss" from the tweeters and Transformer hum nothing (maybe if I had Dog hearing). After 20hrs the unit has Opened up...WIMA will need 100+hrs. I have ordered from Jim McShane a set of MC275 tubes ( 4 KT-88 Genalex Re-Issue, (3) Tung-Sol ECC803S/12AX7, (1) Genalex B759/12AX7, (4) CV4024/12AT7 Mullard NOS).
2. Auto-BIAS system
