I've followed AK advice for several vintage solid state receivers now and the difference in sound, from recapping and from replacing "known-to-be-noisy" small signal transistors to be amazing.
While following along with others' threads and trying to help out with "consider replacing these known-noisy transistors", I've tried to find a "top ten list" or "worst transistors" thread, but found none.
If there is a long-standing "which transistors go bad or go noisy and you should replace when you can" thread, please post a link.
If not, please contribute your "worst, replace ASAP" transistors and what you've replaced them with (understanding many transistors applications are different and the replacement won't always be right).
Warning: these are broad recommendations that WILL NOT BE CORRECT for all applications. It's up to you to do further research, testing. This is only a starting point guide. More detailed guidance is available in dlucy’s guide - how to find replacement transistors and in search results here on AK that you can do on your own.
Note: there are many variations of gain, HFE in the replacements listed below, compared to the original part and its application in your circuit. You should be careful in comparing the actual gain, HFE values you buy to the original part, spec... and potentially buy many more replacements than physically needed so you can test each and select the replacements that match, come closest to matching what your circuit application needs.
Note: some replacements below do not fully match the original component's specs (for example specification Ic of KSC1845 is less than specification Ic of 2SC458... but often the application circuit [in audio signal path] rarely exceeds the spec of the KSC1845, so it is often fine). It is up to you to test, measure.
Note: some replacements require the rotation of the device to accommodate a replacement ECB pinout device to work in place of a BCE pinout device.
Note: The new additions of the Central Semi 2n37xx-2n40xx devices is new to this list and has not been confirmed. More detail in this post.
Note #1: A good thread on 2SA798 replacement using either KSA992F or ZTX795 can be found here: https://www.audiokarma.org/forums/i...nsistor-2sa798-is-there-a-replacement.281614/
Code:
Type Replacement(s) Failure notes
2SA706 EBC TO202 KSA1220, 2SA1837, TTA004B*, MJE15033* Gain deteriorates with age
2SA720 ECB TO92 KSA1013
2SA725 BCE TO92 KSA992, BC327* Shot noise
2SA726 BCE TO92 KSA992, BC327* Shot noise
2SA798 (2x) BC560B, (2x) KSA992 (note #1)
2SA809 KSA1381 Poor heat dissipation
2SC458 ECB TO92 2SC2240, KSC1845, 2N3707, 2N3708, 2N3710, 2N3711 Leakage, noise, static
2SC631 ECB TO92 KSC1845, 2N3707, 2N3708, 2N3710, 2N3711 Prone to failure, noise
2SC632 ECB TO92 KSC1845, 2N3707, 2N3708, 2N3710, 2N3711 Prone to failure, noise
2SC871 ECB TO92 KSC1845, BC549*, BC550* Leakage, noise, static
2SC1000 KSC1815Y Leakage, noise, static
2SC1124 EBC TO202 KSC2690, 2SC4793, TTC004B*, MJE15032* Gain deteriorates with age
2SC1312 ECB TO92 2SC2240, KSC1845, BC337*
2SC1313 ECB TO92 2SC2240, KSC1845, BC337*
2SC1318 KSC2383, KSC2690A Thermal stress, thermal flex
2SC1344 ECB TO92 2SC2240, KSC1845, 2N3707, 2N3708, 2N3710, 2N3711 Static burst
2SC1345 ECB TO92 KSC1845, 2N3707, 2N3708, 2N3710, 2N3711 Poor mfg quality
2SC1400 ECB TO92 KSC1845, 2N3707, 2N3708, 2N3710, 2N3711 Static burst
2SC1451 KSC3503 Static burst, open circuit faults
* = wrong pinout order, so device will work but you'll have to twist and insulate the leads as
you move them to fit the original pinout order.
