Thorens TD-147 Power Supply
jonboy55
Well-Known Member
I need to purchase a transformer for a Thorens TD-147.
Does anyone know of a source for an original or generic replacement.
It is 16 volts, 140 ma.
Thank you.
Jon
I suggest looking at wall warts, the old kind that has transformers in them. Or steal from a laptop power supply, although you only need a couple of Watts. Little transformers can be ordered from Digi-Key and Mouser and Jameco etc. Not a mechanical duplicate but you can usually figure out something.
Hi,
The best thing to do is get a Pro-ject SpeedBox II it'll give you push button speed change tighter bass.If go with the wall wart it should be 16v AC.This will work have a look:
.needledoctor.com/Pro-ject-16V-500mA-Power-Supply-for-Turntables?sc=7&category=1295
