Its a proven fact that we hear things differently from day to day. What we like one day we might not like the next. I might love a 2301 one day and find it questionable the next. So lets say on Monday you like your MC30's and you wake up Wednesday and you don't and you spend the next month rolling tubes try to get the sound you liked on that Monday or improve upon it. You will waist all your time and loads of money instead of enjoying the music. Been there done that. And with out test equipment to make sure your not throwing bath water on the sound you are just playing a game. So listen to your sound system for hours and hours and get to know its personality be fore changing anything and recognize the sound you will learn to love. Because until you do your just taking chances. And like the gentleman says I would rather invest in a good graphic EQ, to touch up a thing hear or there, but you'll have to train your self to know what need s to be changed and what doesn't.
When I went back to Mac power from Crown I immediately recognized the warmer Euphonic sound of the the Macs, partly because of the lower damping factor on my tri-amped woofers and the beautiful clarity and accuracy of the highs above 6,000 hz. The overly warm was corrected using my Parametric EQ's in the 50 to 63 hz region. and reducing the output of the bass amps about 1.5 db. The highs were even more pronounced than with the previous amps but the quality was so muchbetter I chose to leave things alone. The area of the lower midrange from 1,000 hz down to 250 hz measured just as before, but was much clearer and defined. Just the personality of the amps. All the variables haven't changed in the last 4 years. But from day to day I hear the system differently and yet the same. How can you know if something is seriously wrong with your system if you are always chasing the illusive ghost of perfection with an imperfect tube amplifier. Make it the best it can be as Ron has suggested and if that's not good enough, bet a new 275 or 2301, for the quality of sound not the quantity. Remember a 2301 is quieter at 1watt than your Mc 30 and has lower distortion and higher accuracy. If that isn't good enough get your self a pair of 301's and be done with it. Unless you like direct coupled amps like I do. You haven't discovered their sound yet.
