nortoncycler
Hi All, first time poster here in the Sansui forum so hoping I could get some advice / help. I've taken on the challenge of rebuilding a really sad, neglected and abandoned 9090 (non DB) Normally I would troubleshoot and fix prior to a rebuild attempt, but given this poor guy's shape and functional status of "not even close" I figured I would just go through and rebuild everything. Anyway I bought a great kit from "that site" and set about my journey. I got as far as Part 1 - Rebuild the power supply and have already hit a issue / question... during my replacing of the caps, I came across it having a bit different configuration (revision?) than apparently most. Instead of the usual 4.7uf caps mine has 4x 10.0uf ceramics and two additional 2.2uf 100v caps... I've seen a few pictures out there of similar boards, so I'm pretty sure this isn't some ad-hoc mod, but was curious what the rebuild advice would be... Leave the arrangement of the 4x 0.01uf's and swap the 2x 2.2uf's with newer ones. Or swap out the 0.01uf's with the 4.7uf's and do ??? with the 2.2uf's??
All advice, help comments would be GREATLY appreciated!
