Back on the bench is a problematic G-7000. The unit has been fully recapped but there was a previous problem with this unit's right channel (details unknown) because the outputs were mismatched and some work had been done to the driver board.
I am currently getting a bright DBT bulb upon power up and no relay click. IF I pull out the driver board completely and power it up - both relays engage with the proper timing (one instantaneously and the other after 4-5 seconds).
The rails are producing the proper + and - voltages.
I have replaced all transistors and diodes on the driver board.
New pots installed for bias. The bias will not adjust properly as well for either channel.
I installed all new output transistors...OnSemi.
All small ceramic caps were tested on the driver.
I'm concerned about further testing voltages on the driver when the amp is pulling current through the DBT.
Any advice on next steps would be appreciated.
