Bubo
I am looking at rack mounting my equipment, given the pricing of racks and shelves, I hope to get it right the first time.
I will be placing two 19" x 42U racks on either side of the TV, space is tight and this is my only option. Four post racks are too big, so it's two post. Plus I think the gear looks pretty.
From my research, I think the Mac Gear can fit comfortably into the 19" racks, but would like to hear from someone who has done it.
My concerns are:
1. Can the Mac equipment be installed in the racks with the factory wooden enclosures, or do they have to be removed? I think the answer is yes, and it will be tight. Or better to just forget the wood and have access to all of the controls? No wood better for access and heat, but worse for dust?
2. Can the front glass bezels be pushed back into the shelf or do they have to protrude in front of the shelf and rack vertical rails? Again, I think they can be pushed back into the rack if need be.
3. I have listed two shelves from two manufactures that I plan to use, will they both fit the rack, or are the mounting holes and screws different. I think the answer is that both shelves will fit into the rack, but might be different sets of screws which are included with the shelves.
The most viable racks I have found are the Startech 2 post rack with casters. These sell for around $134ea on Amazon.
http://www.startech.com/Server-Management/Racks/DuraRak-42U-2-Post-Open-Telco-Rack~2POSTRACK
http://www.startech.com/media/products/2POSTRACK/PDFs/2POSTRACK_Datasheet.pdf
The shelves are kind of a mixed bag, and I will have to use two manufacturers. This raised the issue of standards, and standards.
For the MC 2205, 85 lbs amp, Startech appears to have a solution in their 2U 150lbs vented center mount shelf, which shouldn't protrude from the back of the rack. I'm planning on mounting it at the bottom of the rack for center of gravity and aesthetics.
http://www.startech.com/Server-Mana...Cabinet-2-Post-Shelf-150lbs-68kg~CABSHF2POSTV
Startech's other vented racks are 16" deep which will leave some of my other gear's connectors hanging over the rear and no lips on the shelf to prevent the equipment from sliding out. Yes we do get earthquakes in IL, much to everyone's surprise.
http://www.startech.com/Server-Mana...erver-Rack-Cabinet-Shelf-50lbs-22kg~CABSHELFV
I did find vented shelves by Tripp Lite that are 18" deep, 60lb capacity, and have front and rear lips which appear small, no drawings available. I am planning on using four of these per rack, with generous spacing for heat dissipation.
http://www.tripplite.com/shared/product-pages/en/SRSHELF2P.pdf
I am planning on leaving the front and sides of the racks open, and spacing the shelves at least a few inches apart to prevent heat buildup and the chimney effect.
Any comments or suggestions will be greatly appreciated.
Thanks in advance for your help.
My concerns are:
