sabocat
Well-Known Member
I've experimented with a few budget record cleaning devices, products, and I've just found one which really works. Merrill's G.E.M. Dandy, which cost me a little more than a hundred dollars, consists of a contraption that you put in the sink and clamp the record onto. It's made out of pvc pipe. The label is covered, and then you attach a nozzle to your faucet, with a hose that you use to rinse the record. There is a proprietary record cleaner in a half quart bottle that you spray onto the record surface, both sides, and let sit for a minute or so. Then you rinse with the cold water nozzle/hose, held at a 30 degree angle. You finish by patting dry with a baby diaper and let dry in a rack for 40 minutes or so. My first attempt was a Coltrane Monk jazzland fantasy record with lots of pops. I'm playing the second side, and nary a pop. Oh, and I didn't get wet using it.:tresbon:
