Rock Solid Speaker Stands
musichal
poet emeritus
I have read and heard all kinds of claims about the effects of speaker stands on sound quality that tend to range from the mundane to the rediculous. However, I doubt that anyone would deny that they can make a huge difference - just starting with getting the speakers to a better listening height is a very obvious element of a stand's function.
Maybe most, or at least many, would also agree that a heavier stand is preferred and can also make an audible difference. However, I can't see paying as much for them, on my budget, as some folks do who are my betters economically.
I am sure that some of you may have stumbled upon the same solution that I found; I have not seen anyone else do this, but it is so obvious that others have undoubtedly done something similar. I bought half cinder blocks (about 7 3/4" x 7 1/2") at the depot, and a couple of rectangular solid blocks of concrete that are the same width as the half-cinders and about twice the length (about 15 1/2" x 7 3/4" x 3 3/4"). Also a couple cans of flat black paint (or whatever color is appropriate, I guess, would work as well).
Painted all the blocks, then used the solid rectangular blocks as platforms for the half-cinders (makes an inverted "T" - viewed from the front - which looks fine). I stacked the blocks with the voids or 'holes' to the center, so they look solid all the way around - they don't look like cinder blocks. You simply measure your speakers first, of course, to see how much lift you need to get the height you want, I wanted the tweeters at ear height (me seated), and was able to get within less than an inch of what I had calculated stacking these blocks.
Also, ever the cheapskate, I simply cut up a couple old mouse pads for dampening between the speaker and blocks, which also prevents scratching of the speaker bottoms as well as any rattling which might occur. This stand provides a very 'massy' foundation for the speaker, and is not pure ugly. One visitor reached down to touch the stand, and was very surprised, commenting that he had thought the stand was actually part of the speaker and expected to feel grill cloth.
"This is concrete, ain't it!" he said. Yes it is, rock solid (and cheap).
So, have any of you done something similar that you like? Also, I'm thinking of using mouse pads for dampening in other audio applications. Any ideas, comments, or reccomendations?
Oh, yes. One other advantage of this stand I have discovered is that if you change speakers (as I just did, going to a larger pair), then it is easily adjustable by removing/adding blocks. And for fine-tuning height, you can always cut a 1/2" or 3/4" block of wood (painted to match, obviously) to insert under the speaker.
Nice!
And you are correct...there have been members here that have dressed up cinder blocks in some fashion or another, including me.
I thought they were a great foundation for my New Large Advents. I just put some little rugs over them to cover them up. Your method probably looks much better.
I ended up getting rid of the cinder blocks when I got my BA A400's going, I didn't need them.
Stained concrete 16"x16" pavers, with painted 3" PVC tubes for feet. Cheap, already 'painted', stable. The pavers work good under a turntable too.
I have used patio stones that sat on top of bolts (as in nuts & bolts) in the past.
Have you tried coupling the speakers and the stands? IOW, try putting something solid between the speakers and stands (cylinder blocks) like three steel nuts per speaker.
Theory is that the vibration from the speaker will drain into the blocks. The speaker will not be isolated. :)
If you have dead speakers (made out of a material that does not ring like marble) you may not notice a difference. But if they are made of wood or wood products, you may hear a difference.
I think that's one of the reasons why speakers are not made of real, solid wood - they're veneer and MDF or something else that's very heavy.
Just a thought (in the wee hours... :D )
I've been using cinder blocks from Home Depot for years for my Large Advents. Mine, however, are untouched up..... I like the natural look. I've also gone one step further by mounting my components on a shelving system composed of the same cinder blocks.
I have used a yoga/exercise mat to keep speaker vibration in check. It cost $2.00 for a 6' x 3' mat at the thrift store. Just cut it up to the size(s) you need. Sorry Jillian Michaels
I put my speakers on cinder blocks too, works well, can't say I have had any other speaker stands though.
I'll add to this nearly 5-year-old thread to say that I too have 1/2 cinder blocks around to use as stands. I stack 3 of them on top of an 18"x18"x2" patio block.
I have felt on the bottom to protect the floor and a cut up yoga mat to go under the speakers.
Eventually, I'd like to bolt them together with the threaded rod I have left over from my more involved speaker stand project.
My speaker stands are, well, other speakers:
I used "Cinder Blocks" (concrete actually) for over 20 years and I was never very fond of them. Since that time I've just built my own out of wood or MDF and PVC Schedule 40 or better. I use sand and many times also include lead birdshot. Works quite well and a bit of paint makes them quite attractive!
Best Regards,
TerryO
I don't think having high quality heavy stands is a necessary option , as long as the alternative is strong and hard . I too was eager to here the song difference of my pioneer hpm-700 stereo speaker. I must say I was not disappointed after lifting them from ground level about 16 inches high , the sound was more cleaner , the vocals were clean and clear and surprisingly the bass was more power full . Sounded better than the muddy bass response it gave when they were placed on the floor before .
I did not use any special stands but two wooden subwoofers which sat just nice and flat under the speaker . After that I tested them for 2 hours and loved the sound they gave more than the sound it gave on the floor, recommended to raise antique babies like these for the full performance
