markus
Master Procrastinator
started (and practically finished) construction on a pair of JE Labs Spec'ed OB's that will fit most 12 inch drivers. I'll eventually make a spacer ring so anything smaller than a 12 inch woofer can be mounted. Check out the link :
http://members.myactv.net/~je2a3/open.htm
Anyone who has toyed with the idea of making a pair of these should GO FOR IT - they are a piece of cake :yes: I splurged on a GOOD sheet of 3/4 inch birch plywood - HOME DEPOT SUCKS ! - all their plywood was warped and smashed. I hit a local lumber place - Howe Lumber - if you buy from a mom & pop shop, you'll probably find a better piece of wood. I paid about $5 more for the sheet, but it is VERY nice . . . .
Tools:
Circular Saw
Jigsaw
Pencil
Tape Measure
Straight Edge
a pair (or more) of 'Quick Clamps' or equivalent
Wood Glue
Coarse Thread Drywall Screws
I'm countersinking my drivers about a 1/4 inch so they're flush, so it is taking a little longer than normal . . . check out the pictures for progress thus far. If I had a circle jig for my router, it would look MUCH better, but too bad for me :tears: I didn't even have a comapss to use to draw my circle, so I found a shelf bracket with the holes of the perfect length to use :thmbsp:
The following 12 inchers will be tested in these - both have a curvelinear cone (cross-section) which should help in the high frequency extension. I'll try 'em first without a tweeter, and then with just for shits and giggles.
RCA c. 1957 12 incher's found in many of their 'Orthophonic' line of consoles
these have been going for about $100 / pair on 'the bay', but if you snag a whoile console, you're sure to find them cheaper (like FREE
Magnavox manufactured/ RCA labeled 12 inchers c. 1956. these have a vented dustcap, which should also help HF extension.
I've got oodles of other 12's, and smaller drivers to use, but these are the two sets I've been itching to try OB.
I'll update the thread probably tomorrow with more progress - glueing and screwing
I know this is *kinda* DIY, but that forum always strikes me as more amplifier and cabling in nature . .
Tools:
Circular Saw
Jigsaw
Pencil
Tape Measure
Straight Edge
Wood Glue
). The horns dont work on either baffle so if I ever get around to fixing/ replacing them my opinion could well change. Ugly as hell, yes but still not ugly enough to part them out.
