KingBubba
"Too Much Stuff"
I am presently repairing an Onkyo TX-4500MkII and between Mouser and Digikey, have been able to find the items I need except for a transistor labeled 2SC945A. On the schematic it is marked as Q507, for those of you who might have a SM for this item, PM me if you would like to look at the SM. This item is marked as "thermo", as opposed to "power amp", on the parts list. It was bridged from the PC board to the heat sink for the outputs with a metal bracket.
I wondered if this was part of a protection circuit that would be activated when the heat sink got to a certain temperature. When tested, the component showed no continuity between any of the contacts, completely open on all.
Is this component fried? or does it need higher temperatures to activate. Does anyone know anything about this item, its use in the circuit, if it is really shot, and most of all where can I find one if I really need it.
Also, in regard to this project I need to get a 2sc1625 o and a 2sa815 o. Mouser has these but there is no letter following the numbers. Is this letter of importance to me. Mouser's replacement was a TIP30C for the 2sa815 and TIP29C for the 2sc1625. Would anyone know if this is a correct replacement for these transistors?
Thanks for any help rendered.
Gary
Gary
