This manual record cleaning/vacuuming system works great. (with pics!)
Brett a
~◦●○o0o○●◦~
This write up is in 3 posts, so please keep scrolling as you read.
I set out earlier this year to DIY myself an RCM. I set this system up as a “good for now” set-up, but as I got further into the project, I realized this system has its benefits, so I’m sticking with it.
It utilizes many tips I've read here on AK. So thank you to everyone who has posted on the subject so far.
Here’s what I use:
First, I had an old, cheap belt drive turntable in the closet. I took the platter and bearing out and mounted into a slab of MDF-like material (actually a chunk of an old teacher’s desk)
Simple:
attachment.php
(you’ll see the notch and the small hole at its base for the drive gear I decided not to use)
One reason I like this set up is because there is room to get my fingers under the platter to turn it.
attachment.php
Here's a wet/dry vac I picked up for $5. (I go to the flea market often)
attachment.php
The DIY record vacuuming attachment. Made from a crevice tool which I slotted with a hot putty knife and lined with strips of paint pad.
Tip: use 2-sided Scotch tape so that the pads are easy to change. I plugged the end, so it sucks through the slot.
attachment.php
Now that the machinery is taken care of, here are the other supplies:
  • Record cleaning solution. I use a concoction consisting of 2 parts distilled water/ 1 part alcohol/ 2 drops of dish soap (per pint) As most of you know, there is plenty online about making record cleaning solutions.
  • Two natural bristle paint brushes One for wash, one for rinse. I have found that these brushes do a better job than paint pads. I buy them at my local Acme Surplus for 89 cents each.
  • Cotton makeup removal pads ($3.99 for 50 @ CVS)
  • A record clamp (got mine used for $20-this is the one I use on my TT)
  • Two platter mats (from two junk turntables) One for dirty side down, one for clean side down.
Now I know not everyone has extra turntables and vacuum cleaners laying around. But if you hang out around here long enough, eventually you probably will. :scratch2:
attachment.php
Now, let’s get to work.
Start with the platter mat designated for dirty side down. Clamp the LP down. I always start by cleaning side one ---helps me keep track should I get distracted. Seriously dusty/dirty records should be pre-cleaned with a damp make-up pad or a rinse under the tap (if you go for that kind of thing).
Using the paint brush designated for the cleaning solution, coat the LP evenly.(Careful of the label!) Depending on how seriously it needs cleaning, I let the solution stand for 30 seconds or so.
attachment.php
Then, with a fluid back-and-forth motion of the wrist, brush the solution into -and the contaminants out of- the grooves. This is where having a free-spinning platter is a bonus. You can rock the brush back and forth with one hand while spinning the platter into position with the other.
attachment.php
After a full minute or more of this brushing business, grab a clean makeup removal pad and gently absorb the fluid from the record. be careful to always use a clean surface of the cotton pad.And don't use a part of the pad you've been holding on to. I get about 4 uses out of each pad. Used pads can be demoted to nasty pre-cleaning tasks.
attachment.php
EDITED on 12/24/2009 to add:
I need to update this thread because i now have a two-schnozzle system. Which is to say i vacuum the wash water off with a different nozzle than the one I use for the rinse, and I don't use cotton pads at all any more.
See post #36:
http://www.audiokarma.org/forums/showthread.php?p=3370260#post3370260
Now, using the brush designated for the rinse cycle, and with the same technique as before, give it a quick rinse-brushing with distilled water. No blotting now. This is the water you vacuum off the record.
attachment.php
Next, I fire up the shop vac, and holding the schnozzle to the grooves, I slowly rotate the record at about 12 rpm (5 sec. per rotation). It usually takes about 8 rotations- I do 4 each way- to get it completely dry.
attachment.php
Next, flip it over onto the mat designated for clean side down. lather, rinse, repeat.
For good measure, I’ll set it to air-dry while I work on other LPs.
This system works really well. The difference after cleaning is audible. And the difference from my old system of blotting dry w/o vacuuming is pretty drastic too. Also,I have yet to see a single black spot on my Magic Eraser stylus cleaner!
The down side to this system is that it requires a bit of set-up and tear-down. It's not as convenient as having an RCM in the living room. But I don't seem to mind.
Thanks for looking.
:thmbsp::thmbsp:
There are some minor updates on post #32
Great pictorial.
I have two questions for you:
1. Does it bother you to have to hand rotate the platter? In other words, would you consider a motorized version better?
2. Is there any fluid coming out of the LP surface? Have you considered planking side rails to the piece of mdf to contain any spill outs?
I have basically the same setup but put the vacuum inside of a box and made a clamp to turn the record. The clamp is just a round piece of mdf with piece of non slip carpet mat glued to the bottom. A dowel glued to the clamp is used to turn the record.
My cleaning steps are as follows:
Vacuum dust from record
Steam record with Walgreen steamer.
Add diy cleaner to the record. Distilled water, alcohol, and Kodak Photoflow.
Use record brush 10 rotations in one direction and then 10 the other way.
Vacuum dry with 10 rotations.
Works great and can clean a record in about 3 minutes.
Great pictorial.
I did motorize it and pretty quickly realized that I much preferred working the platter by hand. I guess I could compare it to whisking a large bowl of eggs. I wouldn't want the bowl to be bolted to the counter; my two arms/wrists work in relationship to each other to provide a feel, a rhythm.
Now that you mention it, the counter does get a little spotted in the line of fire as I brush the fluid into the LP surface. I make a point of being careful where I set the clamp down between record so as not to get it, and the next label wet. So far, (other than this concern) this is not a problem. I can easily vacuum up the excess water now-and then-no harm done. But now you have me thinking about some kind of catch system....
Do you use the same vacuum attachment for the initial dusting and the final wet-vac?
Nice pics and post man. Yeah as you say a nice audible difference ! I Just got home from the Lp store with 5 used that have been hand washed and dried with micro fibre towels by the store . I have one on now and lots of cracks and pops . So after seeing this post I will stop and take them in the other room for a wash , I am sure that there will be a big difference . Wish I had once of these years ago .
Good Job :thmbsp:
I like your idea of using a dedicated mat that only gets used when you put the record clean side down. That should cut the chances of contamination way down.
Think I will incorporate that into my VPI 16.5 cleaning routine.
Good Job :thmbsp:
Yes, I forgot to mention that. I always discarded the idea of RCMs as the just cleaned face of the LP would then rest on the filthy platter. But the Clean and Dirty Mats are a bright idea. If I may enhance it further, one mat could be white (for clean) and another black (for dirty). Or any handy color combination, just for ease of identification.
Well the disc I played earlier is now almost silent (Cooder's -the slide area) . I did 3 discs since my last post . I have not gone to the 2 mat approach nor the DW rinse .I am still using purchased solution so am somewhat on the fence on the rinse ? But I guess it would not hurt ,just the extra work. I'm a bit of slagger I guess :D
Probably not the best idea but I do. I use a nail brush to clean the attachment and if a record is really dirty I wipe it with a micro fiber cloth first.
Same here and I take the wand off and vacum the strips after each clean , then fluff with the little brush .
This is a little off-topic, but what kind of turntable is that platter from? My Sanyo TP-1010 has the SAME platter and mat lol
old cheap belt driven turntable? lol
My record cleaner I just purchase is this machine and saw it on Michael Fremer's video, It's a Vinyl World After All." It's on the way as we speak. :banana:
Haha that's awesome. And here I thought I had a diecent TT! (I read the comments) oh well haha. It sounds good to me, and that's all that matters, eh?
Don't knock it man. (even though I might have :o). That was my main TT for about 6 years. I really appreciated it all that time.
There's always better gear out there. And when you move up the equipment food chain (as I bet you will if you stick with this), you will experience better and better performance. That is the blessing and the curse of this hobby.
So, try not to let my opinion about the 1010 get you down or give you wanderlust. Relax and enjoy...
:thmbsp:
