I'm finally getting around to this project. The "patient" in this case is a set of Wharfedale W60s I picked up locally for $40. Somebody painted them French Provential White. Pictures of the as-bought condition can be seen at this link:
http://www.audiokarma.org/forums/showthread.php?t=201831
I was not impressed with how they sounded in stock form. Listened to them for just a few minutes then put them in the stack of other speakers not in current rotation.
The first task is to strip the white paint off to return the cabinets to their original natural wood glory. Have stripped one cabinet and started the process of refinishing it with Watco Danish Oil - Dark Walnut (see attached pic), one coat on so far.
Have decided to keep the Wharfedale 12" woofer (instead of substituting a OLA 10" replacment or ADS 8" pair). Pictures of the Wharfedale woofer are attached.
The JBL horn takes up all the room available in the top half of the cabinet. So, the 2" vent tube is moving to the bottom half of the cabinet and is being replaced by two 1.5" tubes at 10:00 and 2:00 positions, approximately. This means new baffle boards have to be cut. I'm not a woodworker, so will call on a buddy at work to help with that task.
Stay tuned.......
Regards, BmWr75
Stay tuned.......
Regards, BmWr75
