loneraider
Easy way to make your own record cleaner...one direct drive turntable($10.00 at junk market). One shop vac (small 1 hp should do) i used a hose from a hoover steam vac but any hose will work and you need a a clear plastic tube about 5 to 6 inches long. Dremmel a 4 or 5 inch line on bottom of tube and tape a piece of velvet with paper backing on top of the cut you just made and cut a slit the same length as the one in the tube. Attach the hose and tube together.. I use brushes with camel hair ( $5.00 at Micheal;s craft store
her in ontario) the tube was filled with paper bubble bath stuff ($ 3.00 same store) The velvet with paper backing found at stores that make picture frames. or at fabric land. Cleaning fluid i use is 99% isopropanol,dawn dish soap, and distilled water. Mix 40% isopropanol add a few drops of dawn dish soap and the rest with distilled water and shake it up,,,,,,Put a 2 inch square of solution on album ,wipe around the album with camel hair brush(it looks like a paint brush) and then vacume up......Thats it. It took me a week to make this (finding the parts) If u want to play vinyl then u have to vacume
the crap off and YOU WILL BE AMAZED AT THE RESULTS!!!!!!
