oneinchside
Openly Baffled
I put this over in the general forum and got no response, hopefully we have some speaker design type folks around here... I need some edjumacation.
Ok, I'm pretty confused, at least with horns... I'm going to write out what I *think* I know, mainly so those of you who actually do know can correct me. (please do, I'm here to learn)
Open baffle- optimal size seems to be 35.5"x31.5", placed 3' from the wall. Benefit is that there is no box coloration (does that mean that the wrong box can screw things up?) The front is "in" phase, the back while out of phase is separated by the baffle. The dimensions above seem to be enough to make it work.
open back-partial less bass than the open baffle? If placed too close to a wall the reflection from the opening can interfere with the signal from the front and cause comb filtering. The size of the box and the size of the opening seem to greatly influence the sound, optimum would be calculated base on Vas, Qts and Fs?
sealed box completely separated the in phase and out of phase signal. The trapped air may act like a "spring" and allow the driver to play lower than in an open design. Parallel surfaces may cause standing waves, which may effect the rear of the driver and in effect create comb filtering. The size of the box seems to greatly influence the sound, optimum would be calculated base on Vas, Qts and Fs?
ported box Like a sealed box but with a tube or port to allow some of the bass energy to come out. Size of the box, diameter and length or the port are all crucial as the shape of the port determines what frequency the box is tuned for. Again, the size of the box and the size of the opening seem to greatly influence the sound, optimum would be calculated base on Vas, Qts and Fs?
horn (is this a "back loaded" horn?) The horn acts as a guide not to actually amplify but to remove obstruction in the air so the sound can travel more efficiently. Longer horns would emphasize lower frequencies, are shorter horns as drawn used to improve separation and reduce coloration from other drivers? All of this is calculated mathematically, I guess using T/S parameters.
-----Why doesn't anyone use longer grammaphone style horns?
horn ????? The taper gives some support for the rear of the driver but still has an output for bass frequencies?
-----They look kinda cool?
Horn (is this "front loaded?") Seems to be a popular design from the 1950's to now. Provides midrange and bass, used in many one driver designs also. Approximately 638,987 bajilion variations. I guess it works? Do you need to use the T/S parameters to design something like this or is it just "the longer/bigger it is the lower the bass rolloff" Isn't the information coming out of the horn out of phase with the information coming off the cone?
Bass Horn Seems to very similar to the above but the driver is internal, a small sealed box behind the driver and then a very large horn on the other side. Since one side is sealed, all of the information is "in" phase.
-----Is this basically a big honking gramophone bell? Is all high/mid information lost in this design? Or is the high/mid just very dependent on the texture, shape, and reflectivity of the the internal surface making it darn near impossible to tune for HiFi?
Are there other types of enclosures that I'm not familiar with? I'm sure it's been done, but I would love to hear a shoot out using the same driver in the different types of enclosures.
What other criteria are important in designing a speaker enclosure? Obviously I'm getting ready to make some of my first enclosures, a little guidance would be greatly appreciated.
Thanks
Mike
Thanks
Mike
