mattybass
Young Audiophile
Hey, I'm not sure if this is the right forum, but it technically is tube audio... and old tube audio to boot.
I went to pick up a late 70's B&O receiver/turntable and the owner had two OLD radios next to it. He offered me this Rogers Majestic R186 tube radio for $20, and I couldn't resist. The unit is functioning as he was able to pull in local AM radio stations. A lightbulb on the right-hand side even lights up when the unit is powered on!!
After taking a look at home, it looks like the unit is using the original tubes, or at least was repaired using genuine Rogers Majestic tubes, but I have no clue. Take a look at the photos and perhaps someone can inform me of the true age of the tubes. From what I could tell, all the tubes were glowing (even the one that is charred black inside).
I don't know a thing about tube audio, especially anything before the 70s. I'm hoping anyone can shed some light on the situation and tell me I made a good decision in getting this unit for $20. Also, would you guys restore the wood finish or keep it as it is? Tomorrow I plan to use my compressor and gently blow out the cobwebs and dirt from inside so that the unit doesn't start on fire. I also need to replace the plug as it has exposed wire. I have one that looks exactly the same which is nice.
Anyway...
After taking a look at home, it looks like the unit is using the original tubes, or at least was repaired using genuine Rogers Majestic tubes, but I have no clue. Take a look at the photos and perhaps someone can inform me of the true age of the tubes. From what I could tell, all the tubes were glowing (even the one that is charred black inside). I don't know a thing about tube audio, especially anything before the 70s. I'm hoping anyone can shed some light on the situation and tell me I made a good decision in getting this unit for $20. Also, would you guys restore the wood finish or keep it as it is? Tomorrow I plan to use my compressor and gently blow out the cobwebs and dirt from inside so that the unit doesn't start on fire. I also need to replace the plug as it has exposed wire. I have one that looks exactly the same which is nice.
Anyway...
