Saved from sure death - Sansui 3300 beauty
Audio Fan
YT Channel - https://tinyurl.com/29zytwu9
Several weeks ago, I happened across a really sad sight. This receiver was in a trailer with up to 8 cats at a time over 25 years.....and was never once cleaned. I am still amazed at what I pushed through to save this thing, words cannot describe how nasty this place was, it needed to be condemned. If I had cat allergies, I would have died right then and there.
I just couldn't let this thing go to the dump, so I threw it in the back of the van and rode home with the windows down. Once home, the first thing I did was get my yard blower and blow off what I could. Then I got some paper towels and wiped it down a bit (even though I actually did wipe it down once at the trailer, believe it or not). I then took it out of the wood case and took the blower to it again.
Once I felt I could not make any more progress with the blower, I took it into the garage for more detailed cleaning. Over the course of the next two weeks, I spent several hours wiping down everything I could with a light solution of cleaner that removes animal smell and oils. I used a heavier solution to clean the wood case, kept wiping until I removed all the grime. The front, initially I thought was a gold patina (wrong), I used a citrus solution to cut through the oily residue.
On the inside, hard to believe how much creeps in through the vents over 25 years. It was so bad, I had to take a tooth brush dipped in the cleaner to get the gunk off the boards (very carefully, of course). I took strips of paper towel, sprayed it with cleaner and wiped down every surface I could reach, using a small screwdriver occasionally for tight spots. As well, I went through a box of Q-tips too.
For the case, I ended with some Howard's Feed & Wax. Surprisingly, the case was not damaged, all corners look great, finish still shines.
I put it all back together this evening. Works GREAT! Looks INCREDIBLE! I really cannot believe how good it looks from where I started. I cleaned the pots, all work very smoothly. Check out the before and after pics.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Wow, its cool to see someone with enough dedication to save a unit like this. As others have already said . . . nice save.
Audio Fan,
Great job. :thmbsp:
You now have a very nice nice looking Sansui. :yes:
I am sure it will make some very nice :music::music::music:
Thanks for the pix. Your before and after pix may encourage someone else to
make an effort to save an other wise doomed piece of gear.
Sometimes I can't believe the level of deterioration people let their equipment succumb to. I picked up an SX-535 the other day that had the same yellow patina. An hour with Windex and Q-Tips and I found the silver face underneath.
Thanks all, it was definitely a "labor of love" and it turned out very well. My wife could not believe it was the same receiver. Even the cat smell is gone (I put it inside a big garbage bag with an air freshener for almost two days).
Ain't it amazing how filthy some people live. You did an excellent job with that. :thmbsp:
You are not kidding. I was shocked. There was also a set of Pioneer HPM-900's in there, but the cases were used by the cats as scratch posts, so you can only imagine how bad they were. I thought about pulling the tweeters, pulled off the grills and hair just fell out everywhere.... I left them.
I did save another piece though, a Dual Turntable, so I'll get to do this fun again sometime soon. In the meantime, I'll enjoy the Sansui. Although I'm not technical, I really admire the build quality of the internals. Seems very well laid out, easy to work on, if needed.
attachment.php
The transformation is like night and day...what an effort you put into this!
Sometimes you gotta wonder about people and their habits
their habits were nasty and yours are obviously not
Congratulations are in order for your dedication!!!!
Sometimes I think that the dirt and grime somehow protects the units, also I think that being inside and untouched like that for 25 years is better than tweakers driving around with it in the trunk of the car, or being tossed into the NFG electronics boxes at the thrift store, with it's cord cut off. It's like karma-the cats kept all away until you decided to brave the mess and save these pieces. Nice work.:banana:
BTW-what's happening with the cats?
Remember there is stereo equipment that people gave up on a loong time ago.Makes it easier sometimes to save.It looks great the job you did.All these Sansuis are worth saving.
Excellent job, above and beyond the call of duty. I know that this is an extreme case but it is an example of people living with wrong priorities, and letting animals rule their lives. I personally wouldn't tolerate an animal that pissed on my gear, let alone 8, for 25 years, that makes me completely sick just contemplating. I have more respect for myself AND my gear to ever let that happen. For some folk though, it's anything for these creatures. Not me, thank you.
