Greetings to all. I have refoamed speakers over the years and read up on the various techniques to accomplish the job. It all comes down to 4 ways of centering the voice coil, thee most important part of the process. Some use the "cone push and set" by hand as promoted by the kit sellers, some cut the dust caps and shim, some use the battery method and then there is the signal generator @ 30Hz. This prompts a question. What is the definitive Number One process? I tend to believe that the signal generator @ 30Hz is the top of the food chain, however, I wonder why 30Hz seems to be the "magic bullet" tone setting for all speakers? Shimming has always worked for me provided the voice coil is working in the first place. The battery method raises concerns in terms of potential frying the coils, and the batteries or both !!? A standard AA Battery emits 1.5 Volts, but my Electronics guru (82 yrs of age and still shocking) stated that it would be risky using this process because voice coils are activated in millivolts, thus the difference in voltage and a lack of resistance could burn the coils. Yet others have stated they have hooked up batteries for 4 hrs continuous with no problems? Grey areas remain which only raise more questions for those less informed. My objective is to fill in some of the blanks that exist. I recall a Physics Professor commenting on the battery method which described horizontal and vertical planes of alignment !!?? Even with such an experts advice, the comments still seemed speculative. There has to be expert first hand knowledge of the facts underlaying the 4 methods used to center voice coils. AK is the place to be for such knowledge and information. My objective is to tighten up the loose ends surrounding each process. I thank you all in advance for contributing to this thread.
