Allright man, awesome find! Richard Allan made some very good drivers.
I have the fullrange version of these, the CG10T. I found mine at the thrift store in ratty homemade cabs with 3 cheap cone tweeters each. This RA cone tweeter is probably decent enough, but could likely be bested with a modern unit.
Here is some data I found over the web on RA drivers:
Here are my drivers, used in the 12" Karlson:
The T/S parameters I measured are:
Re: 7.35 ohm
Fs: 38 Hz
Qms: 10.2
Qes: 0.48
Qts: 0.46
Vas: ~115 liters (a bit fudgy to measure, should be close enough IMHO)
BL: 8.25 N/A (WinISD extrapolation)
SPL: 93.2dB/W/m (WinISD extrapolation) that figure is about right
The suspension is one of my favorites, doped cambric, which is said to actually improve with time!
The enclosures your drivers are in look like they are on the small side, especially since they don't seem to have much damping/stuffing inside, so it's not surprising you like the sound with the back off better. They have a rather large Vas so will want large enclosures in general.
Enjoy your pair!
az
