SziTech
Member
Hi all, my first post after lurking for quite some time.
Found a neglected Sanyo TP 626 on Craig's List and after seeing some really nice rebuilds I decided to go for it.
Took it apart and cleaned it thoroughly. You should have seen the headshell! Someone actually tried to solder one of the lead wires, quite unsuccessfully I might add. The turntable was filthy!
Anyway, my question is; how do you remove the tonearm??? I see the two screws on each side but they seem to be set-screws of some sort set inside two other screws. They will not budge!
I have got them soaking in a little drop of 3-in-1 at the moment.
One of the reasons I am trying to remove the tonearm, besides further cleaning, is that the rod the counter weight rides on is loose and can only be tightened from the inside shaft of the tonearm. What luck, huh?
Any input would be greatly appreciated.
Sanyo TP-626:
Look at this soldering job! :thumbsdn:
Set-screws on the side of tonearm pivot: :tears:
Thanks again!
Sanyo TP-626:
Thanks again!
