Caveat Emptor - TC-760LC Hum
First post, not counting the introductions thread.
I have a TC-760LC that I purchased with the intent to run an Audio-Technica AT30E that I acquired very, very inexpensively as NOS. I read several good reviews, some of them on AK, and decided to take the plunge. Ever since I've had it there has been a pervasive 60Hz hum in one or both channels that hasn't been remedied by any usual means (i.e. grounding, moving it away from other electronics and appliances, etc). It's loud enough most of the time to overpower the quieter passages on most records, and can be discerned even on the loudest cuts. It is more noticeable in some outlets over others, and repositioning the unit doesn't seem to have much effect. It is present in both the MM and MC, regardless of if it is hooked up to a turntable or not, although it tends to be more prominent on the MC setting. For some reason, holding the power cord at roughly mid-length seems to at least partially eliminate the problem.
So, long story short it might hum and I don't have a way of troubleshooting it yet.
