Muting Assembly (AWM-039-A)
AWM-039-A: C1: .47uF 50v CEA: 667-ECQ-V1H474JL .47uF 50v
AWM-039-A: C2: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
Equalizer Amp Assembly (AWF-013-0)
AWF-013-0: C1: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C2: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C5: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C6: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C9: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C10: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C11: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C12: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C19: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C20: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C21: 220uF 16v CEANL: 647-UKL1C221KPDANA 220uF 16v
Q1: 2SA725: 512-KSA992FBU
Q2: 2SA725: 512-KSA992FBU
Q3: 2SA725: 512-KSA992FBU
Q4: 2SA725: 512-KSA992FBU
Control Amp Assembly (AWG-027-0) (Check C49-52, can be 100uF 16v instead of 47uF 16v like the manual states)
AWG-027-0: C1: .33uF 25v: CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-027-0: C2: .33uF 25v: CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-027-0: C7: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C8: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C13: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C14: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C15: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C16: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C23: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C24: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C25: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C26: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C29: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C30: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C31: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C32: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C39: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C40: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C41: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C42: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C45: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C46: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C47: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C48: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C49: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C50: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C51: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C52: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
Power Amp Assembly (AWH-032-0) (Times two) (Check board number, the D version does not have the 1.5uF cap.)
AWH-032-0: C1: .68uF 25v CSSA: 667-ECQ-V1H684JL .68uF 50v
AWH-032-0: C2: 1.5uF 25v CSSA: 647-UKL1H1R5MDD1TA 1.5uF 50v
AWH-032-0: C4: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWH-032-0: C8: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
Q1: 2SA726: 512-KSA992FBU
Q2: 2SA726: 512-KSA992FBU
Q3: 2SA726: 512-KSA992FBU
Q5: 2SC1451: 512-KSC3503ESTU
Q6: 2SC1451: 512-KSC3503ESTU
Protection Assembly (AWM-062-0)
AWM-062-0: C1: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062-0: C2: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062-0: C3: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C4: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C5: 4.7uF 25v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWM-062-0: C6: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
Q7: 2SC1384: 512-KSC2690AYS
Power Supply Assembly (AWR-054-0)
AWR-054-0: C8: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C9: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C10: 100uF 63v CEA: 647-UPW1J101MPD6 100uF 63v
AWR-054-0: C11: 100uF 63v CEA: 647-UPW1J101MPD6 100uF 63v
AWR-054-0: C12: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWR-054-0: C13: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWR-054-0: C14: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWR-054-0: C18: 1000uF 35v CEA: 647-UPW1H102MHD 1000uF 50v
AWR-054-0: C19: 220uF 16v CEA: 647-UPW1V221MPD6 220uF 35v
AWR-054-0: C20: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
AWR-054-0: C21: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
R11: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
R12: 10 Ohm 1/4 watt: 660-MF1/4DCT52A10R0F 10 Ohm 1/2 watt
R20: 3.3 Ohm 1/4 watt: 660-MF1/2DCT52R3R32F 3.32 Ohm 1/2 watt
R21: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
Q1: 2SD313: 863-MJE15032G
Q2: 2SC869: 512-KSC2383YBU
Q3: 2SC869: 512-KSC2383YBU
Q4: 2SB507: 863-MJE15033G
Q5: 2SA628A: 512-KSA1013YBU
Q6: 2SA628A: 512-KSA1013YBU
Q7: 2SD313: 863-MJE15032G
Q8: 2SC1384: 512-KSC2690AYS
MTF Echo Wars mattsd: Can someone check this list for me please? Really appreciate all the help so far (especially Larry- you guys rock!)
