I own a number multi-disc sets of classical music, some 25 years old. Most are on the Polygram Archiv label.
This morning I was horrified to discover the foam sheets used to keep the disks separated in the case were severely deteriorated and had stuck to the disks! A four-disk case typically has a sheet of foam over each disk. I've kept these foam sheets because the hubs don't always hold the disks in place without them.
Fortunately, with all disks installed properly in the case, damage was limited to the label side. However, until and unless I can remove the foam, I do not dare insert them in my disk player for fear of contamination!
I attempted to peel off the foam but it simply crumbled, leaving a coating of tiny foam bits stuck to the disk surface. I tried to clean with detergent, but the foam acts like an adhesive. With some effort, isopropyl alcohol removes the foam, but it removes the label ink as well.
I only wish I had caught this earlier, before the foam began to stick to the disks. The foam sheets appeared normal the last time I played these disks, which was probably 3 years ago. If any of you have disk sets with foam inserts, I recommend you discard the foam immediately. I only wish someone had warmed me.
Does anyone have any ideas as to how I can clean these disks? As a last resort, I guess I can clean them with alcohol and forfeit the label markings.
David
David
