Paul C
OK, this is a little strange to me...
I have two power amplifers here that have assymetrical rail voltages.
Both are Onkyo's, very similar but for voltages, voltage ratings on some caps, output devices. Same circuit topology, same boards, layout, etc.
M-5140, rated 105 w/ch at .09% distortion, output devices are STK4044V chips, rails measure +61.2 / - 59.6
M-5150, rated 150 w/ch at .09% distortion, output devices are STK4048V chips, rails measure +72.0 / - 70.6
There are a pair of diodes on the center tap of the transformer, wired parallel, one one way, the other reverse, before it goes to chassis ground. I have not seen this anywhere else. The outer leads of the transformer go to the bridge rectifer, then to the filter capacitors like any other power supply. See page 7 of the attached service manual.
I suppose these diodes are responsible for the offset voltages. But my question is... why?
Onkyo calls this their "Delta Power Supply"... which, other than those two diodes, is pretty normal.
Something to do with the Sanyo ouput chips?
Idle offset voltage on the speaker terminals is a very low 1.8 mv and 2.3 mv... very low. There is no idle current to set, no adjustments. That is automatic internal to the Sanyo chips.
Comments?
Paul
Comments?
Paul
