Kneedeepinit
Had a bit of spare time this week so I decided to make a pair of speaker stands for one of my stereos. The current ones were aesthetically pleasing but didn't tilt the speakers 10 degrees like I have learned to be ideal.
the project had the side benefit of being a wise investment. The two cases of liberated pop are worth $10 and my total cost to build the stands was some scrap wood from the garage and $5 worth of paint + lacquer. I realize the wiring has to be cleaned up but as you can deduce from the missing outlet cover plate, the house is under construction.
the basic design was pretty simple. I cut 4 pieces of wood to end up with 1" less width and depth of the speaker. A full piece in front to hide the end grain. The side pieces were then cut at an angle to give the 10 degree tilt for the speakers. The back piece was left at its original height to provide a rear stop.
Some basic sanding with 120 grit sandpaper, 2 coats of prime, some 600 grit wet sanding, 3 coats of finish gloss black, and then 2 coats of lacquer.
they are very solid and provide a secure base for the speakers
sorry about the crappy light but it is night. I will probably edit this tomorrow in better light.
