I assume you want an antenna for the 88-108 MHz FM band? If so, the easiest thing to do is probably take 2 pieces of wire, each 2.5 feet long and connect one wire to each of the two FM antenna terminals on the back. You want to orient them the same way the transmitter antenna is oriented so you can experiment with the wires going vertical (one up, one down), horizontal (one left, one right), and see how you get the strongest signal. That'll work if your receiver is in a place where it can pick up signals. If your receiver is in a basement or something you might need something more elaborate, like an antenna on the roof or in the attic but I'm not sure about your specific situation.
