Tim D
Yea, I’m muddying the water (-;
Back to the SA-100, and I’ll ask this question again to regain focus.
Anyone have experience using the center channel? If so how was it implemented and what kind of results ensued?
VR
Andy
Dave might stop by with a comment, but my understanding (came from Dave's post(s)) is that Fisher implemented two basic designs for the center channel. (1) A difference signal between the two channels (not a great result as it would cancel similar signals between channels - meaning true mono would give essentially zero output.) (2) A summation signal between the two channels (an apparent improvement from the previous design). I am not sure, but if the SA-100 is an older design and maybe it uses the difference signal, but I'm guessing.
Many don't use the center channel. It was created at a time in stereo history when stereo was young and the split between the channels wasn't always done well. I think the concept was to fill a gap between the channels for (sloppy channel assignment). In fact some hobbyists remove the center channel circuitry because the way the circuitry was designed causes a funny ground arrangement where the speaker common isn't at chassis ground potential. I have a Fisher KX-100 and Fisher KX-200 that both have this funny business and I have to use the 4 ohm tap on the speaker terminals as a ground for turntable connections. I don't like it but haven't removed it yet. I work around it just fine by using the 4 ohm tap (or no dedicated ground from the TT at all) and so I have no urgency to remove it but still I wish it wasn't there. I seem to remember a thread where Dave showed how to remove it from one unit and it changed quite a bit in the output and feedback circuitry on the amp.
