DC offset, turn amp on leave it on for about 5mins....
Attach your DMM to say the left speaker output, set it to read Millivolts....It will probably have a 0-200mV scale....
Adjust VR801 on the left driver board (which is the other trimmer, not the bias trimmer) to read as close to 0mV as possible, you might get it somewhere between 0mV- 5mV which is OK......0mV is a perfect world, we all know this does not exist....
Use small increments, its a sensitive adjustment....
Move to the right channel and repeat......
You could try connecting the Macbook directly to the Power amp in.....MAKE SURE THE VOLUME IS AT MINIMUM on the computer, then bring it up slowly.....I would be surprised if this doesnt get you some audio.....
Do not plug into those inputs with the amplifier on, connect it up with the amp off.....
Let us know how you get on.....:thmbsp:
