I have a Magnavox 9304 console amp that was partially rebuilt--the previous owner replaced the 4 coupling caps but did nothing else. He put in .47uf and .152uf on each channel. I fired it up, and it sounds divine, but one of the EL84s is redplating. I tested the tubes--they're good. I am under the impression that the coupling caps should be something like .47 and .047, or .1 and .01. Is it likely that the redplating is due to his choice of cap values? What values should I go with? Thanks in advance!
