Marantz 250 Large Capacitors
Here are the original caps. Screw type.
if the copper plate is the same size as the one in my 1200 (which it appears to be), then the caps are closer together than the 1200. that would make the epcos even easier to fit (they are screw terminal and require no modification). just need something to shim inside the clamps (as i said, i used rubber tubing).
