The clips/probe doesn't matter, reversing it will turn the signal upside down and with a sine wave that is not worth worrying about...
I'm afraid I don't understand what you're trying to say, but given that the OP is a beginner I have to strongly suggest that he not pay attention to your post since your post is incorrect. Reversing the probe connections will do far more than simply "turning the sine wave upside down". Following your statement can cause catastrophic damage to equipment connected to an oscilloscope.
The proper use of the probe and ground clip does matter, and in fact failing to understand circuit grounds and earth grounds and how an oscilloscope works with grounds is probably the single most serious mistake a beginner can make, along with connecting to a voltage source higher than the scope can handle.
If you have a scope probe connected properly, with the ground clip connected to circuit ground and the main probe connected to the point in the circuit where you wish to measure a voltage and/or observe a waveform, and then you reverse the connections, you will take the point in the circuit where you were taking measurements and make a dead short connection from that point to ground, possibly destroying multiple components in the process.
To Steelman:
First, congrats on wanting to learn new things!! This electronics stuff really is fascinating, and you will find it increasingly interesting the deeper you get into it. Unfortunately, as you're already finding out, learning it all by yourself can be both frustrating as well as compelling. I would strongly urge you to take another look at your local community/junior college Electronics Technology offerings. No, you won't find a course on "Using an Oscilloscope", any more than you will find a class on "Using a Socket Wrench" listed under Automotive Technology. You'll learn how to use the tools when you take a class on how to work on engines. If you take an Introduction to Electronics course, then the next two classes you would normally take are DC Circuits and AC circuits. In those classes, particularly AC Circuits, you'll get to play with scopes for hours on end, and you'll learn a lot. Nothing beats hands-on with the teacher standing next to you.
In the meantime, for a lot more in the way of books, instruction, etc., take a look at this site:
http://www.tubebooks.org/technical_books_online.htm
Scroll about 3/4 of the way down until you get to the section labeled: "Test & Measurement (equipment & instructions)", and you'll find several books on oscilloscope usage.
Enjoy the journey!:thmbsp:
