Hello!
I have recently purchased a Packard Bell console stereo that does not currently work. I was hoping to gain some advice here.
I believe it has a tube tuner and the amp is solid state.
The unit does turn on (light on face of tuner dial turns on and tubes light up). However, I am not getting any sound. When I flip the speaker selection switch (external, internal, both), I can hear static in the speakers. Other than that, nothing.
There is a wire coming out of the amp that is not hooked into anything. It is in one of the pictures I included. Anyone know where this would plug into? Also, the input selector dial (FM, AM, Tape, Phono) spins in a full 360 degrees and has more stops than just the 4 selections . Maybe this is not engaging as it should?
Let me know if you have any ideas on what to check first. I am new to tube stuff. I have done some basic speaker recapping but no major repairs. It appears everything in this console is in good shape so I am hoping its a pretty easy fix and I can do it myself.
Thanks for any help you can provide!
