PROBLEM:
The unit does not sound right. It makes cymbal crashes and other highs way too bright. Overall, the sound seems "unbalanced." Vocals sometimes get lost behind the music. It just sounds bad.
SOURCE:
So I just bought this unit on ebay for $200. It shipped from Japan. I cleaned the RCA connections, then removed the top and sprayed De-Oxit on the switch contacts, then worked them up and down several times.
I did not try it out before cleaning it.
SETUP:
Here is the signal path: Denon DL103 on EPA-100 arm in a Technics SL-1000 (SP-10 Mk2). [Alignment, VTA, VTF all good.] OEM Tonearm cable (w/ grounds) to the Denon SUT input. Toggle switch set to 40ohms as per the instruction manual. Output cable (incl. ground) to MM input of Cambridge 651P MM/MC phono preamp. Phono preamp output (Blue Jeans RCA cable 6') to AUX input of my Sony audio preamp.
TROUBLESHOOTING:
I tried both inputs on the SUT (1 & 2) with the same results.
I know my phono preamp is fine (along with the rest of my system). I use the MM input for my MM carts and they sound great.
Records sound much better with the DL103 going straight into the MC input of my phono preamp (Either wiring straight in or using the "bypass" setting on the SUT) instead of using the SUT.
QUESTION:
Anything wrong with my setup?
Is this a common problem with SUTs "of a certain age"?
Can it be fixed? I'm pretty handy.
Should I return it?
Please don't suggest other SUTs, preamps, carts, cables, etc. right now. I'll ask for that on a separate thread if I want to. I just want to focus on thie Denon SUT for now.
..and yes, my records and stylus are very clean.
Thanks, guys.
SOURCE:
SETUP:
TROUBLESHOOTING:
QUESTION:
Should I return it?
Thanks, guys.
