pradigmshift
I recapped my IMF TLS-80mk2's with poly's. Although this was an improvement, I needed to add resistors to my mid and high drivers to compensate for the lower ESR compared to electrolytic. Since the loudspeakers are supposed to sound natural I am now struggling to find the right resistor values. Decreasing the highs has brought back the sound prior to recapping. Decreasing the mid with 1 dB has made the sound smoother, but also less prominent with voices. Only a frequency test with microphone would give the right outcomes but I don't have one right now.
If you replace electrolytic capacitors with the same brand and type, assuming they are still available, you avoid this bad kind of resistor juggling. But poly will sound better especially in the highs.
However, whether elcap or poly, it seems everyone here agrees old elcaps should be replaced.
Here is the link:
