dogwan
Dogwan
Anyone using?
Have service manual or schematics?
Just picked up a nice clean unit as "parts or repair... does not power up".
Got it home and 1st thing I checked was fuse. Instead of 1/8 (.125) amp it had a 1/4 (.25) amp fuse. Looked good but tested dead. Closest to spec I had was a 1/5 (.20) and put that it.
Hit power and no LED but did hear relay click.*
I pulled fuse and put Ammeter in-line and under power it's drawing about 240mA (0.24A). That would explain the larger fuse.
Have not tested for sound or function yet. The fact that it's drawing about 2x the current of the stock fuse rating tells me it's not too healthy. At least it's not shorting or drawing an insane amount of current. Looks like I will need to tear into this unit before using.
Hard to find any info on the SAE 2800. There is a person selling a "rebuild service" on eBay for about $230 and that posting has the only nudie shots I've been able to find. Looks like about 6 quad op-amps are involved in the circuit. I do see there are a few handfuls of electrolytics that probably should be replaced. Hopefully any significant problems are in the power supply or the electrolytic caps.
I'm hoping I can get this beauty back to her former glory. Apparently, this was the EQ to have back in the day from what I've read. I have seen two different MSRP of $550 and $700 in 1978 dollars. That explains why they are pretty rare.
Any help of info is greatly appreciated.
* in searching for schematics I found a couple references to a service bulletin about LED power modification, so maybe LED is burnt due to not having the correction done?
All those sliders a probably scratchy /dirty.
