Thanks for info. Well, I powered on again this morning after a night of setting. I did a super job last night with the spray cleaner. It has improved some with cleaner but still does not make consistent contact. I believe it may be something else. What do you guys think? Here is two crazy things I noticed last night. Number one: All knobs turn nicely without noise. However, the balance knob and the volume knob seem to make a contact noise when spinning back and forth. Number two: There seems to be excessive magnetized. Every time I remove a screw it will literally lift out of the hole a stick to the screw driver. I set a screw into it proper hole and move the screw driver near it and it will lift out of hole. Is this normal. I remember some magnetization but not this excessive. This "BAD BOY" from what I have been told is close to be shelved.
Skey
Skey
