Brian4561
Now that I have a little tube preamp building experience under my belt, I'm starting to think about building a tube amplifier from scratch. I know its a huge step up in complexity, but its something I want to try.
It will also be a while until I actually start to build the thing. First, I have a Foreplay preamp kit that will be coming soon. Second, I'm planning that it will take some time to figure out what circuit to use, to have some knowledgable folks weigh in on the circuit plan, to source the appropriate parts for the build and to get a chassis figured out. That's why I'm starting now.
So where to start? I'm thinking I'd probably do a set of monoblocks rather than a stereo amp. My intent would be to run the kit preamps through the monoblocks. I'm not sure how much power I would want--with my current speakers, I don't know if anything under 30 wpc would work at all.
I'd also like to do a pretty high-quality circuit, one that has the possibility of doing some tube rolling and perhaps some later modifications.
So any suggestions on how I should start this process? What circuit should I look at?
