+! on Testing with meter after cutting off the tip.
I was going to mention a meter but if he had one (and knew how to use it) I don't know if he would have asked in the first place. :scratch2:
A light bulb won't let you know the polarity. The wall wart in the picture has a DC output.
Everyone should have a meter. For $15 plus ~$5 shipping the one in the link below can't be beat.
http://www.amazon.com/gp/product/B0006FKF5Y/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Not really. You could take a coin and flip for it.You're right ..... if I had one, I wouldn't bother asking.
But since I'm asking means I don't have one.
So, seeing that I don't have a meter, is there anyway I can tell without light-bulbs (and such) which of the two wires is (+) and which one is (-).
There's no set rule, but I'd guess the one with the white tripe is positive. Generally, when there are two connections/wires, the positive is marked and the common/negative isn't.Is there some sort of "standard" for wires with a white stripe on them?
It's right there on the wall wart under the word "LISTED". The center of the plug is +, the outer sheathe is -.
if you have a length of insulated wire and an iron nail i could tell you another way to test it .
Saw that.
Still doesn't tell me if the white stripe wire is center or outer sheathe.
:scratch2:
