klamsoss
Be willing to fail and try again.
Hello all! I'm in the process of fixing up a 212 for a good friend of mine and I'm stuck on step 4 of the electrical adjustments outlined in the service manual.
Let's back up..
I started by checking the function of the 'table when I got it... The power switch, of course was broken and wouldn't stay on. Next, one of the touch lights was very dim and sometimes flickered, plus neither of the 45 or 33 touch lights would stay on. The motor spindle at least turned when you held your finger on 45 or 33, but it wouldn't stay on if you took your finger off the touch button. As usual, the stop control bulb was completely burnt out. And of course the melted drive belt. Yuck!
So i did the following:
Cleaned out the melty belt and replaced that after cleaning the surfaces well with alcohol. Then I put a new power switch in (watch that wiring! check it with an ohmeter first so you know what to connect where. The switch I used had a different setup). After that, I got a set of LED replacement bulbs for the touch buttons and end control.... All 4. those went in without any drama other than that the 33 bulb socket had been damaged. I replicated the lead-soldered-to-bulb-base setup that had been in there, and at least lit the bulb. Clearly someone has had this 'table open before me...
So now I'm trying to get the electrical adjustments done properly. I got the speed and supply voltage set correctly, but on step 4, it indicates that the voltage across R404 (the light dependent resistor, LDR) should be set to 0.75V b adjusting R465. I can't get anywhere near 0.75V b adjusting R465. I'm 90% sure I am measuring it correctly... there are two grey wires that come out of the LDR and connect to the main board. I have my probes between those two wires. I can get maybe down to 4.5V, but that's it.
So I did some searches on here and vinylengine and I see that it's perhaps impossible to get 0.75V across that LDR. Okay... but the issue I am having here is that the auto-stop happens before the end of the record.
Additionally, the touch buttons for speed are... iffy. If you leave your finger on there or rub it across the button a bit, it'll stay lit, but otherwise, it just switches back to 'Stop'. This is something I can live with, but it would be nice to fix. I've tried swapping the old bulbs back in, which did nothing, and i've cleaned the contact surface with alcohol. It doesn't seem to improve anything.
Any ideas?
Let's back up..
Any ideas?
