Vintagecasey
I have a dumb question on the 4230 looking at it from the front is the amp board on the right side for the quad and the amp board on the left side for the regular stereo? My first question with this is I bought this thing knowing one channel wasn't working thinking it would probably be an easy fix. When I took the amp board on the left side (looking at it from the front) out there was actually a burn hole through the board. I looked for a replacement amp board but none available at this time. I've removed both the left and right amp boards and mark them right and left, to try to follow the traces on one side to the traces on the side that the board is burnt and can't really tell where they go. As a test, could I replace the left side and leave the right side completely disconnected to see if the stereo works or will that not work that way.. thanks
