Thanks for the explanation. I have seen tube amps with a small trimmer capacitor across the feedback resistor. I wondered what you would trim to, or how to see "correct" trim. Makes sense now. Paul.
I am sure there are many factors relating to square wave over-shoot and ringing. I do know that the test I did on my EL34 did show feedback does have an effect.The AD2 allows you to run a continuous wave signal. If the amp under test had that feedback trim pot, it could be adjusted while watching the Square wave I imagine.
My experience from testing and then listening: Amps with a short duration overshoot on a square wave sound detailed and more open. When I have added caps or done other things to eliminate this in testing, the amp sounded dead/woody with a reduction in perceived detail. I quickly quit worrying about this, and actually worry when it's not there.I would think that this square wave "ringing" should be minimized, but since audio is sine waves, how much does it really matter? Does a small amount of square wave ringing effect what you hear or measure in audio? Paul.
This is 100% correct and matches my experience as well.My experience from testing and then listening: Amps with a short duration overshoot on a square wave sound detailed and more open. When I have added caps or done other things to eliminate this in testing, the amp sounded dead/woody with a reduction in perceived detail. I quickly quit worrying about this, and actually worry when it's not there.
Can you post a loop-back of the analyzer (generator out to analogue in), so we know what we are dealing with here?
Have not found any way to do this using the AD2, BNC breakout board and Audio Analyzer Suite software.
The second picture above answer all your questions @gadget73 ?what are the actual connections for this? I'm guessing you can get output to an RCA plug to get into the amp, but whats the connection arrangement on the speaker side of things?
Don’t think I have a cable like that but will look. Never had any BNC cables before getting this AD2.yup, BNC in, BNC out. Do you have a BNC to BNC cable? Connecting the input directly to the output with a cable should be all you need to run a loopback test to see the analyzer's internal performance.
There is no "best to last", just information on the THD vs power etc. It's not difficult to learn to read a 2D graph.For those of us dipshits not experienced in graph reading (me included) I'm be curious to see the results in a spreadsheet format w/text, listed best to last (or vice versa).
Harmon Kardon Trio A224 integrated (1959 vintage push/pull EL84)
Had to use the balance knob to get the Sine waves to match up. Ended up setting it to about 1:30 o'clock. Can't remember what EL84s are installed in this amp, but that might have something to do with the channel imbalance and other differences shown below. Also have no idea what is causing the weirdness on the THD vs. Power chart starting at about 3.5 watts, but it is coming from the Input Signal (green line). I've seen this strange behavior before testing other amps.
