Does anyone still have the BOM for this project? I have hunted for this to no avail. Thanks!
This thread is SO old now, any BOM would have at least 50% of the parts no longer available or otherwise out of stock.
This forum is all about people helping others. No offense meant, but a lot of people come on here just looking for BOMs without doing any of the legwork themselves. You would be doing a great service to this forum by building a BOM of current parts. I can help by providing the guts of the old BOM I used to use. You can import it into Excel by cutting the text below, pasting it into Notepad, saving as a text file, and then renaming to a CSV file. Excel should then pick up the commas, and put all the data in the correct cells. For power supply caps, look for low impedance types. For signal path work, look for low leakage or film caps.
Kenwood KA-7100 capacitors,,,,,,,
Main Board,,,,,,,
C,C,uF,V,Notes,Mouser Part,Qty,Sort Order
19,20,10,25,,,2,1
21,22,10,25,,,2,2
15,16,10,50,,,2,5
17,18,10,50,,,2,6
41,,10,50,,,1,9
39,,100,16,BP,,1,10
40,,100,25,LL,,1,11
25,26,100,35,,,2,12
27,28,100,35,,,2,13
29,30,470,50,up to 1000uf 63v,,2,16
31,32,6800,50,up to 63v,,2,18
33,34,6800,50,"65mm h, 30mm dia, l/s 15mm",,2,19
bypass caps for mains,,,,4 x 1uF film,,4,22
,,,,,,,23
Front board,,,,,,,24
3,4,330,10,,,2,25
5,6,47,10,,,2,27
7,8,10,16,LL,,2,29
17,18,10,16,LL,,2,31
19,20,3.3,25,LL,,2,33
21,22,10,16,LL,,2,35
23,24,3.3,25,LL,,2,37
25,26,0.33,25,LL - was tant bead,,2,39
27,28,330,25,up to 470uF 35v,,2,41
,,,,,,,43
Back board,,,,,,,44
3,,100,16,,,1,45
5,6,47,10,,,2,46
15,16,220,6.3,,,2,48
17,18,3.3,25,LL,,2,50
19,20,220,25,up to 330uf 35v,,2,52
,,,,,,,54
Resistors,,,,,,,55
65,66,220,,replace with 2w,71-CPF2-F-220-E3,2,56
77,78,100,,replace with 2w,71-CPF2100R00FKE14,2,58
,,,,,,,60
Trimmers,,,,,,,61
VR1 - 4,,500,,replace with multi-turn,652-3296Y-1-501LF,4,62
,,,,,,,63
Miscellaneous,,,,,,,66
Qe34,,2N3904 replace with,1 x,relay driver transistor,512-KSD1616AGBU,,67
,,,better,2SC3902,863-2SC3902S,1,68
De27,,replace with,,relay diode (1N4004),625-1N4004E-E3/73,1,69
,,,,cap across power switch,81-DE2F3KH103M,,70
,,,,cap across power switch (better),539-104M06QC100,1,71
,,,,relay,653-MY4-02DC24,1,72
,,,,heatsink for PSU transistors,532-577304B00,,73
,,,,mica insulators,534-4651,,74
,,,,,,,75
Outputs,,2SD427,NPN,replace with MJ21194G,863-MJ21194G,,76
,,2SB557,PNP,replace with MJ21193G,863-MJ21193G,,77
Drivers,,2SC1567,,replace with KSC2690A,,,78
,,2SA794,,replace with KSA1220A,,,79
Main PSU diodes,,GP25D,,replace with 1N5404,512-1N5404,8,80
,,,,,,,81
,,2SD427,NPN,TO-264 version (TO3-P),863-MJL21194G,,82
,,2SB557,PNP,TO-264 version (TO3-P),863-MJL21193G,,83
