I am now at the point where I can attempt to power up my repaired M-85. Since the Left channel was not damaged at all, I have now soldered the connections to the
power transistors for the Left channel only. I have an 8 ohm speaker connected to the Left channel only. No speaker or load on Right channel. Also all of the power
transistors for the Right channel are NOT connected. I was troubleshooting a DC offset problem with Right channel and believe it is now fixed. More about that fiasco in
another thread. So for now I am monitoring the AC Line input current, plus the bias test point for the Left channel. With the Bias Set potentiometer set to zero ohms,
what should I be seeing for bias current at the test point? Right now with 120 volt AC applied I am seeing zero milliamps. Voltages on Left Channel Output transistors
Q131 +37.3vDC Q133 +37.3vDC Q135 -36.7vDC Q137 -36.7 DC offset on Left channel output 1.7mv
Comments???
Karin
Comments???
Karin
Once you get them off of the circuit board. You should be able to get Deox-it to where it will do the most good. They will probably clean-up just fine.
