Tom_r
Well-Known Member
I recently purchased a Heathkit AA-13 integrated mono tube amp. For those more familiar with it's predecessor the model AA-161, it's basically the same except power supply caps are bigger and the schematic appears to have correct values for the voltage measurements. I've attached schematics of both.
I'm looking at re-capping the amp so I'll be replacing the film caps and p/supply can with separate e-caps under the chassis. I can check the resistors for out of spec values ... or are there some that should be changed to film types anyway.
I have no problem performing the work and am getting better at reading schematics (I have 30+ years experience reading AND interpreting Architectural blue prints), but design is another story so here are some things I was pondering:
1) I saw mods to the phono section of a Heathkit AA-151:
http://audiokarma.org/forums/showthread.php?t=432956
I'm wondering if someone could suggest the same mod modded to suit the AA-13?
2) What do I need to do to use the Xtal input as a line input?
3) I will be connecting a tuner to the tuner input, should that circuit be left as-is?
4) This post mentions changing the 6AN8 to a 6u8:
http://www.audiokarma.org/forums/showthread.php?t=355525
Is it just a matter of changing some of the wire connections around on the socket or should some caps/resistors also be changed? I have numerous 6U8/6GH8 tubes and their brothers.
5) Are there any other mods or updates that should be performed (other than a new power cord)?
Thanks.
Thanks.
