pioneerhip
Yes. CAREFULLY reread my last post #77 (especially the section I quoted from you) and then look at the SM for that board and its transistors. Your next hint is this problem was not due to the legs being reversed (though that will still be a factor for new transistors). Also, reread post #62 as it also offers a clue.
I was mistaken about what was used. I actually used an 1845 and not a ksa992 as previously mentioned. Im still searching. I did replace the original 1845 because the legs were gold close to the bottom of the transistor. I replaced it and the aux side is back to working. still the same with the phone 1/2. only one side is passing audio.
