What capacitance and voltage did you replace C100 with. It is vastly different from the M-60/65 and the M-80/85 models.M85 M80 M65 M60 Amplifier Recap kit
Nichicon Muse 100µf 25v non-polarWhat capacitance and voltage did you replace C100 with. It is vastly different from the M-60/65 and the M-80/85 models.
M-60/65 ----- 100µf/25v
M-80/85 ----- 47µf/25v non-polar
I don't think you can use the non-polar cap in this case.Nichicon Muse 100µf 25v non-polar
I was very thorough recapping the amplifier, double checking each as it was removed.
The most obvious thing I'm thinking is the bias voltages got out of alignment and I'm too much into class B operation. Does this make sense? Does the presumption of a simple basic amplifier follow with the larger more complex amplifier?
Why would you ever not be able to use a nonpolar capacitor in place of a polar capacitor?I don't think you can use the non-polar cap in this case.
You have great hearing for a 125 year old.I used a different set of speakers and a different amp; the clarity was much higher. Switching those other speakers from the other amp then to the M65 proved a significant decline in clarity and general good sound.
Let's just call this maintenance for now but sometimes a guy gets lucky. The older serial # M-60's have a small ckt board attached to the RCA inputs with resistors, heck I can't remember all the parts but there's only a couple. IIRC the resistors are fusibles. Might be worth a tolerance test. I had bad solders on that tiny board too. RCA's might need a D5 squirt, wouldn't hurt.
The later serial #'s direct wired the RCA's to the input attenuator board.
Is a bipolar cap in the C100 spot a bad idea? Original is a blackgate polar as you know. The cap kit gave him a BP.What capacitance and voltage did you replace C100 with. It is vastly different from the M-60/65 and the M-80/85 models.
Excellent soldering & board clean up.
Yes. I replaced this relay after it failed and double checked the reflow.Excellent soldering & board clean up.This probably isn't the issue but, why leave all that flux cheese around the big heat sink mounted trannies?
4 of 6 of the relay contacts are stashed under the black cushion. Did ya yank the cushion & reflow all contact solder points?
It gets rid of the noise generated by the zener diode which in turn is used to keep the current through the dual FETs constant. It’s common practice to use a 100 μF cap around zener diodes.What role does C100 play in the circuit?
I now have more questions than answers. The dual FETs? As in all the output stages?It gets rid of the noise generated by the zener diode which in turn is used to keep the current through the dual FETs constant. It’s common practice to use a 100 μF cap around zener diodes.
Thank you; I don't understand what you mean by TO3P and APS transistors? I think I already tried reflowing everything I had touched.The only other thought I had was double checking the poly caps under the TO3P trannies on the left channel. Just give them a wiggle and see if a lead came loose. I've had those poly's come loose while reflowing the outputs & APS trannies cuz the leads are stashed/shared under the tranny leads.
Anything beyond today's chat is beyond me & will leave ya to the more learned techs. Good luck Mr. Chicken.
I kinda like smell of old flux in the morning honestly...A lot of the flux is original from Yamaha lol
