No, I wouldn't go that far. The only records it has trouble with are either severely warped, or cupped 180g records.
Agree with you there may be better options
A hard edge blip/warp will not be forced down on the up side, the down side will get helped a bit. This is also dependent on the weight of the record thin is easier than thick disc, is it a hard short 2" warp or a long 6" soft gradual warp.will any clamp help a record that is warped out by song one, even a small blip??
Considering most of the turntables used with the clamps have a "fixed" spindle, how would one go with a turntable that has a removable spindle, such as my Dual 1225? The single-play spindle is a drop-in unlike the stacking spindle which can be locked in place
No disrespect but I started this thread to teach members why we need clamps, what clamps work best, why they work best and how to use them. If the clamp can not flatten a record, it's not working right and if you seen the OP, and what I effectively did with fairly inexpensive clamps that are designed right then I taught you something. These plastic clever clamps don't do what I did in the OP, spending $20 more dollars is a no brainer IMHO. Maybe a upgrade is in order for you and you can really see the difference after you have had some hands on.
Oh god, thanks that got me laughing.I would never entertain spending $35 on something with less complexity than a disposable fork.
Excellent my friend, thats the inventiveness needed to work around clamps that are good in all respects but don't have a hollow cavity. You can find rubber o-rings also that you can use, a bit stronger and more pin=point in focusing the pressure.Before and after:
View attachment 1151156 View attachment 1151157
Wanted to try something before defiling the ADC.....although I agree it doesn't do what it should, couldn't get myself to start ripping it apart. Soooo, I used the clamp as a template, cutting around it to make a neoprene disc that is exactly (exacto knife....errrr) the same diameter. Then I needed something to cut out the inside portion of that disc to form the border you were talking about and found that my cocktail shaker top was the precise dimension that I needed so used it for the job. Double-sided taped it to the bottom of the clamp which formed the raised circumference and then put the washer back on, then the record, then the modified clamp and guess what? The second picture is the result so I'm gonna sit back and start listening with it on and off to see what difference it makes. This is only a prototype, and should it perform as I intend, I will start over and make something with a bit more precision.
No clamp here......ever.
Some people consider that ideal...akin to a platterless TT. I like the softer microdynamics this can bring as it sounds more natural to me, but the macrodynamics seem to disappear, so for me it's a non-starter.No clamp here......ever.
The collet recedes into the clamp, making it an open bottom.While I like what looks like a nice build quality, and the clamp force can be adjusted in the images you posted, it's a flat bottom.
To better this clamp IMHO, I would take the foam pad off, and glue a rubber O-ring to the outer edge to effectively make a hollow cavity. But I also can't tell if the diameter is the size of the label, this is important also. But that diameter can be extended also.
I briefly experimented with the platterless approach, and found it introduced euphonic colorations like a "rich" enhanced spaciousness. Essentially undamped record resonances of various types adding harmonics and delay effects. I use either a Michell reflex clamp or the oem clamps on my turntables, the HK T60 came with a weight spec'ed for it.Some people consider that ideal...akin to a platterless TT. I like the softer microdynamics this can bring as it sounds more natural to me, but the macrodynamics seem to disappear, so for me it's a non-starter.
