JBL SA600 side panels
cspyon
AK Subscriber
Hi
Can anyone help me remove the side panels of this unit?
I checked the side and rear parts of this unit, but it looks like they're fixed to the main unit.
Thanks for your help in advance.
There is one wood screw that affixes the panel from the inside along the bottom edge of the chassis and one keyed slot which mates to a screw the goes into the wood panel and sits proud of the panel itself. If you remove the bottom panel you can see and remove the bottom screw after which the panel slides out towards the rear. SA600.jpeg
There is one wood screw that affixes the panel from the inside along the bottom edge of the chassis and one keyed slot which mates to a screw the goes into the wood panel and sits proud of the panel itself. If you remove the bottom panel you can see and remove the bottom screw after which the panel slides out towards the rear. View attachment 3777494
Problem solved! Thank you so much, jonsan. I located the two screws on both sides of the bottom panel, securing the panels. I unscrewed them, then pushed out the panels gently. They came out easily!
