nope RSPM mk3IMF TLS-80??
That's what Kenwood called brass. And brass stands for aniodised Metal fronts. Gunmetall always is painted/coated at Kenwood.Very nice. You don’t see the gunmetal version too often.
This thing is of beauty!
Very cool! Thank you for sharing pictures of these! I have had many kenwoods but never of this line.One of the most underrated series of Kenwood receivers. The KR-Receiver from 1970/71 with
KR-2120, 3130, 4140, 5150, 6160, 5170, 7070, KR-33L, KR-44SL and KR-6170 Jumbo.
Really valuable receiver. Massively built with excellent internal components and high-quality, above-average features. All were available with wooden cabinets. These always had very high-quality real wood veneer (walnut). The version having "only" a steel casing was rarer – although technically the standard version. I'll put them side by side. I don't have a picture of the 2120 anymore; it got lost along with a hard drive damage. I can't provide pictures of the 7070 and Jumbo yet – those still need to be taken. Since I was so impressed with the series' capabilities, I've owned each receiver at least twice, some up to four times... But it's getting less common.
I hope this provides a good overview of the qualities of this series. All knobs are turned from aluminum, without any plastic interiors.
I was hoping that I could pick your brain. I put new belts on my KX-1030 but now it is running slow. Is there a place to adjust the speed?KX 1030, I installed new belts, Dolby chip, Speed adjust, Sounds wonderful
There a trim pot behind the motor. Use like a jeweler screw driver to adjust. Counter clockwise to slow downI was hoping that I could pick your brain. I put new belts on my KX-1030 but now it is running slow. Is there a place to adjust the speed?
Thanks for the reply. I gave that a try but it didn't make any difference. The screw only moved about 1/5th of a turn in either direction.There a trim pot behind the motor. Use like a jeweler screw driver to adjust. Counter clockwise to slow down
That doesn’t sound right. That speed pot could be bad. Have you tried different tapesThanks for the reply. I gave that a try but it didn't make any difference. The screw only moved about 1/5th of a turn in either direction.
