About a year ago I decided to make a 'mono' system, do so on a budget, and do it with 'separate' power & Pre amps. Long story short, I ended up converting an old EA-3 to UA-2 specs, and it turned out beautifully. I also included an 'umbilical' out the back that powered the pre-amp. Next I did a complete rebuild of an old WA-P1, but 'deleted' the phono section. This essentially left me with a 1-tube (12AU7) preamp gain stage with what I believe can be considered an 'active' tone control section, as the bass and treble controls are between the two triode sections of the 12AU. I used all new parts and followed the schematic meticulously! The power amp alone is dead quiet, no hum, and sounds great! The pre-amp, on the other hand, is OK, but has a low-level hum that appears when the tube warms up and begins conducting. It's worse as the bass control is turned up, but seems unaffected by the treble control. I can turn the power amp 'on' with a separate switch built into the unit, or with the power switch in the pre-amp that runs thru the umbilical. So, with the power amp 'on', there is no hum from inter-connect RCA cables. Seems all a function of the pre-amp itself once operational.
So, my question to the group here is just what might be suggested to alleviate this issue? I have tried a few different tubes, thinking the noise might be the tube itself. I'm also thinking about it being some kind of 'filament' noise...... but if so, not sure how to progress with that. The pre-amp itself has no 'hum' balance' type control, nor does the power amp that I recall building into it. SO...... just wondering; what about maybe a pair of 100 ohm resistors off either side of the filament wires to ground? Or, any other thoughts? I'd like to tame this hum issue, so I appreciate any suggestions anyone might have. Many thanks!! WC
